2000 Porsche 996 C4 Millennium Edition
For Sale2000 Porsche 911
Price
$35,000• OBO
- Location Mooresville, IN, 46158, USA
- Condition Used
- VIN WP0AA2991YS620905
- Trim Carrera 4 Millennium Package
- Mileage 92,847
- Engine 6 cyl
- Drive Type AWD
- Transmission Manual
- Vehicle Type Coupe
- Exterior Color Other
SALE PENDING
2000 Porsche 996 C4 Millennium Edition - #520 of 911 produced -Violet Chromaflair paint – Natural leather interior Stock seats + Matching GT3 seats - OEM Aerokit - Supercharged – Porsche Sport Exhaust - PSS9 suspension – parts to restore to original - and much more
This one has everything, and can be a show car, daily driver, or track day car
92,847 miles
$35,000 - located in Indianapolis, IN area
More Photos and Video HERE
Body:
Color Violetchromaflair), in excellent condition. Amazing color change: purple-brown-gold-green, depending on light and angle of view. Hard to capture in pictures
Bumper/hood/fenders/headlights have clear bra.
Genuine Porsche Full Aerokit with a Mk2 Gt3 front spliitter. Litronics headlights. Painted rear bumperettes.
Have original front bumper and engine lid+spoiler. small amount of unobtainable touch up paint.
Windshield replaced Sept-2021 due to rock chips and cracks
Das Schild (LidLiner) frunk protection liner
Interior:
All Natural Leather interior (dash, pillars, center/rear console, rear speaker panels, door panels, knee bolster, steering wheel, etc…).
PCM1 Navgation , Alcantara roof/sunroof. Door Handle/Steering wheel/shifter is Dark Wood. Interior is clean, door pocket lids are cracked .
GT3 seats in very rare matching Natural Leather, with extra optional alcantara inserts, ,
Porsche Tequipment bolt-in roll bar with Schroth 6-point harnesses
Stock original heated seats. All in nearly perfect condition.
Engine:
3.4l, original dual row IMS. Updated AOS. RSS Plenum. X51 oil pan. Manual on/off for front/rear fans. Sprint booster for throttle by wire-(3 settings, OFF, Medium, Aggressive). Oil changed every 3k miles or annually with Motul 5w40. Engine/Transmission, no leaks. Porsche engine/oil pan skid plate. New engine compartment battery cable to starter+alternator installed.
Water pump changed (have original pump showing no wear on impeller),
Low temperature 160 thermostat. Coolant changed
AC compressor replaced with near new take-off, plus new dryer
Supercharger:
EVO/VF Engineering Vortech SC Kit. @5-6 PSI, GIAC tuning, bigger fuel injectors (stock injectors included), water-cooled intercooler. (using OEM front 3rd radiator, circulation pump is located near the transmission below). Molded Intake plenum, recirculated waste gate. EVO/VF have dynoed this kit @355hp to the wheels and 360lbs torque (6psi only available at WOT). Power really wakes up above 4k rpm. Kit was installed by PO
Original airbox and injectors included.
Exhaust:
PSE Porsche Sport Exhaust with manual, auto silent/loud mode button/switch (defaults loud upon turning on the car). Relay bypass to turn off stock speed switch for PSE, FVD X-Pipe, Gemballa headers. Exhaust note is sublime.
Suspension:
Bilstien PSS9 adjustable coil-over suspension, H&R adjustable Sway Bars TRG drop links, adjustable rear toe links
New front lower control arms w/ ball joints, front control arms w/ poly bushings
GT3 alignment specs and ride height and corner balanced
Brakes:
Stock calipers – rebuilt front May-2020 rear 31-09-2021 , slotted Rotors, braided steel lines,, GT3 cooling scoops, ATE brake fluid 27-Sept-2023 (changed annually).
Brake pedal assist spring “upgrade” (original spring included)
Transmission:
Original clutch and (dry) RMS
Gbox detent (for second gear pop out), B&M short shift kit,]
rebuilt front axles and boots
B&M short shift kit.
Wheels:
Stock chrome wheels 18x8 and 18/10 have been sanded down and painted black, with winter tires(old)
Sport Classic wheels 18x7.5 225/40 and 18x10 265/35 Michelin Pilot Super Sport
Issues:
- smalll door ding of passenger door. Likely candidate for paintless-dent-repair. happened on my last day of work.
- small dent in rear bumper face
- cable for engine lid release is broken somewhere between the interior handle and the lid latch. I use the "emergency" release cable tucked behind the bumper to release.the engine cover,
- headlight washers are chipped/broken
I wish you would take a trade and cash as I have an09 Audi S4 cabriolet with 44k miles and can’t justify another winter driver
and these Audis are underrated in my opinion the perfect do it all car
Not sure if you're interested in a BMW M2 for a possible trade it all.
$40k at the very least
Too many cars and too much Parkinson's...
