many m97.21 engine parts. Cases/ cams/ pistons and more
For SaleEngine - Internals
I have a lot of 3.4/ 21 engine parts. I did a rebuild and in my quest a lot of parts were bought. I would like to see the whole lot for 6K Plus shipping. However I will separate. those prices are listed with the items in the below list. the items are located in Page AZ Zip 86040. At my place of work, Page Honda. We have a loading dock and fork lift. Arranging shipping will be up to you. I will get items ready for shipping. The entire lot is about 800#
2 cases. $1500 each
3 intake cams with the VVT sprocket $400 each
4 Exh cams $150 Each
4 total heads:
2 heads with matching valve covers $450 each ( leaking valves)
1 head with cylinder/ Valve Damage $250
1 Head with minor external damage that will not affect the head $250 has new valves
1 crank block $200
1 crank block with crank $2500
1 set of OEM pistons and rods $500/ set
1 set CP Corillo forged rods $600
4 trays that hold the valve tappets $100 each
and many other small misc parts. guides, chains, tensioners, nuts/ bolts, and what not
