Capristo | 2019+ Cayenne Turbo 9Y0 | Exhaust | Carbon Fiber Tips
For SaleEngine - Exhaust
CARGRAPHIC Primary-Cat-back Sport Exhaust System with integrated electronic valves and Carbon Fiber Tip Matte Black.
Taken off a 2019 Cayenne Turbo. Ready to ship! Comes with everything photographed. If its not pictured its not included this is referencing any clamps/hardware etc. If you have any questions please ask.
Contains:- CARGRAPHIC downpipe set (non-resonated) without secondary catalytic converters
- CARGRAPHIC centre silencer replacement pipe, 2 into 2 H-pipe construction
- CARGRAPHIC sport rear silencer
- 2x CARGRAPHIC electronic exhaust valves to be used with OEM actuators
- 4x CARGRAPHIC 100mm sport tailpipes, round double wall, slash cut, rolled-in with perforated insert, T-304L lightweight stainless steel - matt-black thermopainted
Valves closed: Quieter tuned enhanced sporty SOUND note, practical pleasant cruising mode
Valves open: Aggressive amplified enhanced SUPER SOUND note, sharper, crisper and volume increasing freer flowing mode - also accompanied with burbling and backfire with every application of the accelerator pedal
NO DRONE OR RESONATION even with further CARGRAPHIC exhaust components
Fits for:
- Porsche Cayenne Turbo 4,0l V8
Features:
- Absorptive silencer design with CNC mandrel-bent pipework
- Integrated electronic exhaust valves
- Fully made from T-304L lightweight stainless steel
- High performance components, dyno tested
- Olive- and slide connections enables easy installation and perfect adjustment
- Aeroquip fittings allow heat expansion without cracking
- Reinforced laser-cut brackets
- Exhaust valve specification as used by OE / factory manufacturers
- Reduced backpressure due to freer flowing
- Reduced operating temperature
- Maximized performance
- Improved throttle response, freer revving
- Improved enhanced acoustics with no drone, resonation or vibration
- Improved low level tone with sharper, crisper and volume increasing sound with revs
- Model specific tuned sound still in keeping with the Marque
- Weight reduction
+11KW(15PS) more power and +15Nm additional torque
Attention:
Factory Porsche valve control can be used.
Alternatively, our optional available CARGRAPHIC performance valve control unit (EXFLAPRCOEE3E) enables full control of the electronic exhaust valves:
Sport Mode - Valves are always open
Comfort Mode - Valves are alway closed
Automatic Mode - OEM valve control is active
Fitting Service:
Benefit from our fitting service in our modern and hightech workshop. A team of qualified, experienced technicians fulfill all your needs with due skill, care and diligence.
