Best Setup for GT4
Old 02-04-2023, 01:31 PM
Fredman6
Fredman6's Avatar
Originally Posted by PGTGULF
Futura trailer here and no need for extra ramps. Very minimal to no scraping when trailer is well positioned even with 19 inch track wheels.
I see you load facing forward, I take it you have no issues getting enough tongue weight? Do you have the 16’ or 19’ version?
Old 02-04-2023, 07:18 PM
PGTGULF
PGTGULF's Avatar
Yes, no issues whatsoever with tongue weight. Once I loaded backwards and almost ruined my wing. Wing must be in the lowest position and then it barely goes under the tire rack. But it’s very close and I did not feel comfortable. Futura trailer is 16’.5 version.
Fredman6 (02-04-2023)
Old 02-04-2023, 08:20 PM
lowside67
lowside67's Avatar
What do you use to measure tongue weight? Seems hard to believe that there's enough tongue weight with the car's motor behind the axles and no tools/wheels up front.
-Mark
Old 02-04-2023, 09:17 PM
ExMB
ExMB's Avatar
Received 1,327 Likes on 807 Posts
-Mark
Actually that car is mid engine. For tongue weight measurements with house hold tools see the bathroom scale method described on etrailer.
Old 02-04-2023, 09:29 PM
De Jeeper
De Jeeper's Avatar
Received 3,281 Likes on 1,713 Posts
U only need/want 10% in the tounge so thats what 450 lbs in that set up. Gas cans, winch and tires would probably even make it too much.
Old 02-05-2023, 09:28 AM
PGTGULF
PGTGULF's Avatar
-Mark
No issues with tongue weight. I have a hitch with tongue weight scale in the ball mount from Weigh Safe. This was recommended by Futura.
Quick Reply: Best Setup for GT4
