Minimum Battery Size for Winch?
If I finally install a winch I hope I won't ever need it. At this point I am considering a 3500-4500 lb winch which should have sufficient capacity to load my 3100 lb car onto a Trailex enclosed that is hardly spacious in the front interior.
I would like to minimize the size, weight and cost of the battery. Anyone have experience using a deep cycle AGM battery that is considerably smaller than group 24 / 650+ CCA, which is usually recommended?
Premium Sponsor
I would get a bigger battery actually. Keep in mind you can use any size battery you can find at Walmart like and H5 battery. You don't really need a deep cycle if you just winching a Car on and off.... but yes it would be better but a bit bigger. Another cool thing you want to have is a small solar panel and a solar charger to keep the winch battery topped off, the work great.
Premium Sponsor
So if you go lithium you have to look at what you are winching and how many amps you need to supply. A Lithium Starter battery is great for non super-high currents with big winches because the starter battery can put out serious current for shorter periods... but not too long or they may over heat and be damaged. I use one now in my trailer that I speak of above in my first post, and it pulls a 66 Mustang RestoMod quite easily up and down the trailer....better than the smaller lead acid by a long way. But again is depends on what you are pulling and for how long and some other factors to make the best choice. We recommend them for lighter pulls like pulling cars up ramps and such but not for pulling trucks out of ditches and stuff... they just put out to much energy to fast and can overheat....unless you had a big one. So Lead is better at those type of things since it doesn't produce as much current so fast and there is not BMS to overheat.
Rennlist Hoonigan
which cost no drachmas
For Lithium Battery they MAY work well for winching but the problem is they are not as good for HEAVY winching.... meaning towing trucks out of Mud bogs and heavy duty stuff.... the problem is they offer massive power in the starter battery format but that can over heat faster due to the level of current they can put out. The issue with the DEEP CYCLE versions of Lithium... which we also make... is that they are a different type of battery cell that is intended for energy storage, but not high current output like a starter battery. So even a 100Amp Hour Lithium Deep Cycle is usually only rated for about 100-150 constant Current amps and if its overloaded it will just turn off. And the 200Ah Battery can be used upto about 200 Amps continuous current... BUT often times whiches can draw 300 amps....
I use a 2500lb winch and a Deka powersports 30 battery on my trailer to load my 996 Cup. Works like a charm and I don’t have to risk burning up my clutch. The winch might seem small but it’s a rolling load which I would think is less than the weight of the car (maybe half?).
There is no need to go small on your winch and battery capacity. Assume that one day you are trying to get your disabled car onto the trailer. Maybe the car is on 4 rolling dollies because the wheels are not turning or missing. That's when you wish you had a stronger winch. Also, get the biggest battery possible because you this is not like starting up a car where you are focused on cranking amps.
