TV mount for trailer
Old 07-06-2017, 03:23 AM
ngng
ngng's Avatar
Default TV mount for trailer
Looking for recommendations for a fixed TV mount in the trailer. I've seen some VESA mounts with the ability to lock, but, is that enough to keep the TV from ending up on the floor?
Old 07-06-2017, 03:48 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,491 Likes on 2,272 Posts
check 24chromim trailer diary he has a great mount
Old 07-06-2017, 04:23 PM
24Chromium
24Chromium's Avatar
I would by no means trust an off-the-shelf mount mount for a home (static) environment. The shock and vibration in a trailer as it bounces down the horrible roads of CA are way more than you might imagine.
Mine is a simple flat plate of aluminium. No articulation of the TV.
Old 07-06-2017, 05:29 PM
linzman
linzman's Avatar
I bought a mount which is easy to disconnect. I plan on taking the tv down and storing it in the original packaging when on the road, only mounting it when at the track. Haven't actually put the mount on the wall yet.
Old 07-06-2017, 09:28 PM
ngng
ngng's Avatar
so you just bolted your TV to your plate, then into the wall? ship it
Old 07-07-2017, 09:46 AM
asamhall
asamhall's Avatar
I'm installing a Master Mount 408L with the next week. It's an RV Mount with articulation. Only mounting a 15lb 32" LCD though.
Old 07-08-2017, 08:13 PM
Tom W
Tom W's Avatar
I have used a simple VESA mount for a 32" monitor (old and heavy) without issue for a couple years. Bolted one side tot the wall with some reinforcement and then attached the monitor. It works great.
Old 07-22-2017, 11:30 AM
Obturate
Obturate's Avatar
I use a simple, cheap mount. Drove 7500 miles this season so far and while other contents have shifted, the TV has not.
Quick Reply: TV mount for trailer
