Mark this thread as Unsold
Spec Boxster Build with Freshly Rebuilt Engine
Year: 1999
Make: Porsche
Model: Boxster
Mileage (numbers only please): 50
Color: Black
Price (no $ sign please): $29900
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
Unfortunately, due to work obligations, I have not been able to drive it. It has only been used a few weekends before the rebuild. I just had my shop rebuild the engine. As you can see from the build list, the car was built with quality in mind.
$29,900 / offer.
I also have a 20 foot aluminum enclosed ATC Raven trailer for sale for a package deal.
Please contact Travis Smith at Pinnacle Motorsports for more information / questions. travis@pinnaclemotorsports.net or 303-565-6868
Thanks for looking!
Ready to Run Competitive Spec Boxster Build listRebuilt Spec Boxster motor with rebuilt heads and LN Engineering reworked block and pistons (Fully PCA compliant)· Just installed by Pinnacle MotorsportsCenter radiator addedCoolant expansion tank160 degree thermostatTrans cooler kit with fanShift cable clips installedLN Engineering LMS upgrade when motor was rebuiltMagnetic drain plug2 qt deep sump oil pan 3 qt accusumpOil cooler with fanRemote oil filter4” underdrive crank pulleyFabspeed SPB race ExhaustLightweight flywheel Power steering cooler PSS9 shocks Tarett front sway bar with extended drop links GT3 arms all cornersTarett rear toe linksTarett rear drop links Tarett rear sway bar or stock have bothFront and rear tie down hooksAll calipers rebuilt Customized brake ducts Stainless steel brake linesLong wheel studs Wiring harness was lightenedLight weight batteryFront and rear hood pinsAftermarket top Lexan front and rear windowsRoof netWindow netCenter netSPA fire system NRG quick releaseSparco PROADV race seat (2011) with Autopower seat braceSchroth PROFI 2 6H harness (good though 2022)Brey Krause seat mountWide angle mirrorCenter radiator grille Cool suit SystemDriver side floor leveling plate AIM MXL2 system Smarty cam HDSensors:Throttle position Brake pressureOil temp Water tempTrans tempOil pressure Spares:Spare builder motor
1 set Rain Wheels / Tires1 set of staggered 986 boxster wheels1 set of new (stickered) Toyo Spec Tires
Here are the in-car videos from ATL Speedwerks who built the car.
In car videos:
WGI
(2nd, 2nd, and 1st, still sorting out the handling)
VIR
(track record and 2 wins, got the handling dialed in)
Summit Point
(3 wins, .017 off track record)
In car videos:
WGI
VIR
Summit Point
