Mark this thread as Unsold
1990 964 C2 Track or Street - Motor w/ 31K miles
*SOLD* 1990 964 C2 Track or Street - Motor w/ 31K miles
Year: 1990
Make: Porsche
Model: 911
Cont. Porsche Models: 964 C2
Mileage (numbers only please): 131000
Options (Please check ALL which apply): Alarm System, Antilock Brakes, Intermittent Wipers, Power Door Locks, Power Steering, Power Windows
Color: Grand Prix White / Black
Price (no $ sign please): $30000
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
I’m selling my 1990 964 C2. It’s been parked since the 2011 Club Race at Road America, so it’s time to move it on to some other p-car enthusiast to enjoy. Overall, it’s a fun car with some very nice upgrades and solid track capability. The paint is nearly flawless and comes with a low-mileage motor and transmission.
Motor mileage: 31K (replacement)
Basic equipment: Manual transmission, LSD, PS and ABS; No a/c, heat, driver airbag or audio
Estimated weight: 3,190 lbs w/ 180-lb driver, 40 lbs of ballast, spare tire and ¼ tank of fuel
I purchased the car in 2006, ran it in 3-4 track events per year over five years and parked it for the last two. It came to me as a street car which I converted to PCA Prepared G Class spec. I’ve provided a full list of modifications below but here are some highlights. Again, current mileage is 131K:
@ 123K: Transmission rebuilt. Installed Porsche Motorsports 8:32 ring & pinion set, steel syncros and lightweight flywheel
@ 124K: Installed JIC CROSS suspension
@ 127K: Replaced MOTOR with a used, low-mileage ‘90 964 motor; Valves adjusted; Installed new oil cooler and hoses
@ 128K: Tested compression and leakdown: “All cylinders at 170 psi and 2-4% leakage” – Perfect Power, Buffalo Grove, IL,7/6/09
@ 130K: Corner balance and alignment; Replaced suspension bushings with ERP monoballs and spring plate; Installed new brake rotors, fuel pump and starter motor
In short, this car has evolved into a well-sorted and very capable performer. At the 2011 Road America Club Race, it posted a very respectable 2:36:7 and ran flawlessly during a weekend comprised of 3 sprint races, an enduro and multiple practice and qualifying sessions. It handles great, shifts smoothly and stops quickly. While it hasn’t been dyno’d, I’d estimate HP numbers typical of a healthy, stock 3.6.
As the title suggest, this car is also streetable and titled. For those interested in high-performance driving events but not trailering or limiting their car to track time, the adjustable shocks, muffled exhaust and 3-point belts allow you to enjoy the car without a helmet or earplugs (see video). Also, the graphics are vinyl and easily removed if you want to remain relatively stealth.
Issue
As with all pre-91 motors, mine does not have cylinder head gaskets. It “weeps” a little when hot and a typical track day leaves the deck lid stained with oil spray and consumes maybe a half quart of oil (out of 12). A quick wipe will get it clean and the residue underneath might result in a few wet spots. But for what it’s worth, after two years of sitting, the system retained the same amount of oil as when it left the track, so the leak is not constant.
Here’s a link which breaks the issue down further and outlines steps/cost to remedy the issue: http://www.instant-g.com/Products/36...HeadLeaks.html
Pricing and Extras
Given the head gasket issue, I’m asking $30,000 obo. In addition to the car, you’ll also receive a second set of wheels, ChaseCam, Cool Suit system, AiM basic lap timer and complete radio system (less the helmet mic, earbuds and plug). Aside from the original jack and tow bolt, no other removed parts remain available.
Pickup only. Cashier checks, wire transfer or other form of verifiable payment required prior to car and title transfer. Please feel free to email me with questions and your phone number if interested in buying. Thanks! email: jfmartinez7@comcast.net
Joe
Photo album (high res): http://s1201.photobucket.com/user/jf...0Porsche%20964
Modifications and Upgrades
Motor:
31K-mile stock motor
Compression/leakdown: All cylinders at 170 psi and 2-4% leakage (checked 3K miles ago)
EVO Motorsport intake w/ cone filter
911Chips performance chip by Steve Wong
Imagine Auto Billet upper valve covers
WEVO “blue” motor mounts
Rennline engine carrier reinforcement bracket
Exhaust:
Stock heat exchangers
Schnell cat bypass – straight pipe
Stock primary muffler with baffles removed
FVD G pipe /secondary muffler bypass
FVD 102mm rolled exhaust tip
Transmission:
Factory LSD – still within spec
Porsche Motorsport 8:32 Ring & Pinion
Steel syncros: 2nd, 3rd and 4th gear
Sachs clutch
964 RS lightweight flywheel
Porsche Motorsport short shifter
Upgraded shift linkage w/ heim joint (replacing plastic cup socket)
Porsche solid transmission mounts
Suspension:
JIC CROSS 15-way single adjustable coilovers: 550/674 lb springs, cushioned monoballs, front camber plates
ERP Control Arm Monoballs
ERP Trailing Arm Monoballs
ERP Adjustable Spring Plates
Porsche 18mm adjustable rear sway bar
TRG 25mm adjustable front sway bar
TRG strut brace
Tarrett rear drop links
Wheels: Mille Miglia 7-1/2 x 9 x 17, 52mm f /47mm r offsets (two sets)
Brakes:
Big Red Brake Kit: 993TT front calipers, 964 Turbo rear calipers
Modified proportioning valve (internals removed) for better f/r balance
Pagid Orange race pads
Rotor dust shields removed
Track Prep:
Recaro SPG seats
Brey-Krause Seat Back Brace
Crow 6-point harnesses – Mfg date July ‘11
Autopower bolt-in roll cage
ChaseCam PDR100 in-car video system
Cool Suit, floor mounted and hardwired
AiM lap timer, dash-mounted and hardwired
Race communications – two handheld radios w/ chargers, in-car mounting for handheld unit, wired for antenna, helmet connection and steering wheel press-to-talk (PTT) button
Momo Mod 07 steering wheel
Fire extinguisher
Schroth window net
I/O Port wide-angle mirror
40 lbs of ballast secured to rear passenger side floor
Battery/alternator kill switch
AMB Transponder
Interior Mods:
Appbiz RS America door panels
Silver gauge faces
Rennline Adjustable Gas Pedal
RS console tray (cassette holder replacement)
RSA/Turbo console tray (spoiler switch replacement)
Exterior Mods:
MA Shaw fiberglass 3.8 RSR decklid and wing for narrow-body 911
Porsche 3.8 RSR splitter "winglets" with stock valance
Headlight trim rings painted satin black
Intake duct/oil cooling (fog light replacement)
Porsche Aero mirrors
Deletions:
A/C compressor
A/C compressor engine mounting bracket
Rear heater blower (block off plate installed on fan shroud)
Cruise control
Engine under tray
Engine bay sound pad
Audio speakers and amp
Front and rear floor carpet/sound padding
Rear seat backs
Rear interior quarter upholstery - under windows
Car jack, tool kit and trunk carpet
Questions/Answers
A/C and Heat. These can be restored. I've removed only the components located in the engine compartment. The dash unit, harness plugs, a/c condenser, dryer and all other hoses and ducting are still in the car. The a/c requires a compressor with attached hoses, refrigerant and a stock motor console (current eBay example). Heat requires a complete blower with sensor and ducting from the heat exchangers. While not intended as an exhaustive list, I believe those parts represent the main add-ons if you want to go down this path.
Wrecks and Collision. This car has never been totaled, salvaged or in any head on collision. Damage has been limited to relatively minor side and bumper impacts and always repaired to a very high standard. More importantly, the car's handling does not suffer any ill effects from prior impacts, i.e. alignment specs are easily achieved.
Logbook. Yes, this car comes with a PCA Vehicle Logbook.
Videos
Test Drive 9/22/13:
Autobahn CC Fun Race 6/21/10:
Autobahn CC Full Track 6/21/10:
Ah ... motor pic!
Here's what it looks like from underneath. Photo taken 10/4/13. This is after a couple hundred miles of spirited driving and without benefit of a wipe down. Hi res version can be viewed here (just keep clicking on magnifying glass at bottom right).
Guys Joe is a fantastic guy and has taken great care of this car. I have seen it first hand and also driven against it. With hours that low on the motor and all the mods, it is an absolute steal at this price! Sad to see it go Joe! Hoping it stays local!
Another vote for Joe. Great guy to deal with, and car has been well cared for by a top local mechanic. Sad to see it go, but someone will get a great car for a great price!
Dont you dare think of selling too Ben! Lets try to convince Joe against his decision to sell this sweet 964 and get more G cars out there again! Joe what do you say....You, Ben and Oscar need to all come out of retirement!
Thanks, guys, for the props.
Sorry to leave you hanging, Mo, but I'll do what I can to see that this car ends up in the hands of another track regular.
Nah.. Taking it to Eurosport this week for regular maintenance. It might be a few years, but I'll be back. Can't see selling it. I'll jump back in next year if you take care of my kids and their crazy schedule....
