Mark this thread as Unsold
'86.5 Porsche 928S3 5 speed
Sharkaholic
Year: 1986
Make: Porsche
Model: 928
Cont. Porsche Models: 928 (all)
Mileage (numbers only please): 121521
Options (Please check ALL which apply): Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Guards Red
VIN: WP0JB0921GS861396
Price (no $ sign please): $13000
Private or Dealer Listing: Private Listing
Location (Region): NorthWest
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Lloyd Mats front and rear.
GTS mirrors (manual adjust)
GTS shifter **** and boot
928 Intl short shifter
Aftermarket Code Alarm system
x-pipe (Louie Ott)
RMB
Sharkvent (928 Specialists)
Intake Refresh new sensors air and coolant, new TPS, new CPS, new TPS extension wire and connectors.
Tuned CO using PorKens' Blinker'
Rebuilt MAF (John Speake)
New Vacuum lines, vacuum pull is 17.5 at idle
Timing belt done with Porkensioner, all gears fine Stock unit comes with the car.
Electric fans installed Spal, (928 Motorsports Fan kit)
New front Spoiler
Drop Links front and rear (Louie Ott)
Bilstien Shocks with stock springs
New Rotors Zimmerman cast hole
MM Turbo Twist Wheels with turbo center caps
Goodrich stainless steel brake lines
Clear front turn signal lenses w/amber bulbs
Steering rack bushings (aluminum from 928 Motorsports)
Pan gasket
Motor Mounts (928sRus)
New Rear license plate marker lights & housings.
Polished cross brace
New ignition final stages and heat sink paste
Fyrebraid Jacob spark plug wires (performance products)
Cams timed with 32'vr tool, set them at -1 +1
55bar bias valve for increased rear braking (stock 19bar available)
Stock airbox is complete and whole with no cracks or damage
PorKens S300 chipset, with adjustable fuel regulator
PorKens air intake torque rings
Porsche 928 Sport Steering Wheel (black)
New aftermarket Cargo cover (black)
Alpine cd player
HVAC completely functional
New hoodliner installed.
Needs speakers to go with the 10 speaker system that is part of the newer S4 interior
Rock Crater in the windscreen, needs to be replaced but I haven't found an in the glass antenna style yet.
Paint is a 6 out of 10, many chips here and there and has two spots by the rear quarter windows where corrosion has bubbled the paint.
New H4 headlights with rockguard installed to protect the glass lenses
This 928 does not have smog equipment so if you live where that is a problem then look for a different 928.
$13000 OBO
Sharkaholic
Sharkaholic
For info consolidation Link to VIN post:
https://rennlist.com/forums/11462130-post388.html
WP0JB0921GS861396
1986.5
C02
M28.43
G28.11
M018 - Sport Steering wheel with elevated hub
I158- Radio Monterey
M319- Changed setup of fan
M418- Side moldings
M481- 5-speed
M490- Hi Fi Sound
M494- Additional amp
M533- Alarm
M570- Rear A/C
M650- Sunroof
1986.5
C02
M28.43
G28.11
M418- Side moldings
M481- 5-speed
M490- Hi Fi Sound
M533- Alarm
M570- Rear A/C
M650- Sunroof
Team Owner
Glad you sold that car, it sure looks pretty, interior color is rare for a red car
