Vehicle Marketplace - Old A place for Rennlist Members & Sponsors to sell their new & used vehicles.
Mark this thread as Unsold
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
Porsche 944 turbo
Old 04-11-2015, 04:05 PM
mr.meroli
7th Gear
mr.meroli's Avatar
Default PORSCHE 944 TURBO NEW TURBO, SPORT SEATS, tons of bolt-ons.
Year: 1987
Make: Porsche
Model: 944
Mileage (numbers only please): 160000
Options (Please check ALL which apply): Sunroof
Color: White
VIN: WP0AA2594HN151689
Price (no $ sign please): $3600
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 4 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
This is my first post.
I've owned the car since 2008. My uncle owned this car 10 years prior to me.
I took very good care of this car.
Had a small fire that didn't burn very hot. When it ran It I was noticing a small tic..tic..tic when I was low on oil, the spark plug closest to me always fowled first. Other than that the car ran like butter. Always put 93, and Lucas fuel lubricator religiously. (this was about 60k after rebuild)
After buying everything again wire harness, brand-new computer, all new sensors, oil pump, the car hasn't been able to run longer than a minute. I have replaced the top end of the motor, including all the reservoirs and mass airflow.(Removed for engine work) The car has a clean title. The car does not need anything but a motor rebuild ( just guessing it may not need a full rebuild) and paint. The turbo has less than 2,500 miles on it. (Thermal coated) sounds fantastic at 16psi.
The praise and compliments from this car are insane.
7272598745 - James
This car has quite an extensive parts list: all have been installed within 2 1/2 years Excluding sensors and computer(2-3 months) And buying the same Parts that were destroyed. Everything is there and nothing is missing.
(forgetting some things) PARTS:
Brand-new DME, Dark tint, Custom fiberglass nose, Custom 944 door sills, Custom fiberglass side skirts, Very expensive front splitter, 968 side mirrors, 968 doorhandles, 968 spoiler, Clutch master cylinder, MSD ignition, aluminum blow off valve, duel port wast gate, crossmember, Custom turbo floor mats, fire extinguisher, wide band air fuel ratio gauge, digital fuel mapping, K&N air intake system, Aluminum gauge bezels , sun visors, MOMO pedals, shifter, and steering wheel, short shift kit( upholstered shifter), carpet all around, 13 speaker sound system (very costly), genuine Porsche sport seats (very rare), fuel lines, fuel pressure regulator, koni adjustable shocks, 3'' Stainless steel magna-flow exhaust (sounds mean), Lindsey racing chips (Also have stock chips), injectors 55ibs , wires, Timing belt, water pump, Steering rack, ac compressor , brakes, slotted and drilled, stainless brake lines , wheels, larger turbo,(Super 53 T3 water oil cooled),adjustable boost inside cabin Most of the weatherstripping is brand new, Crankshaft rpm pulse sensors, All-around new brake sensors, and basic maintenance, Constant oil changes.
mr.meroli is offline
Old 04-11-2015, 04:39 PM
mr.meroli
7th Gear
mr.meroli's Avatar
All the work done to this car was done by a professional mechanic.
Eurotech autobody.
German Specialties.
Old 04-12-2015, 12:34 AM
ForceReconTrojan
ForceReconTrojan's Avatar
You should sell me your seats and take my excellent leather seats in replacement. GLWS
ForceReconTrojan is offline
Old 04-20-2015, 01:51 PM
Shortacus
6th Gear
Shortacus's Avatar
Where are you located?
Shortacus is offline
Old 04-22-2015, 12:18 PM
mr.meroli
7th Gear
mr.meroli's Avatar
Im located in tampa florida.
Old 04-22-2015, 02:24 PM
pkt1213
pkt1213's Avatar
I am assuming the hood, fender, headlights etc is how it now sits since the fire?
pkt1213 is offline
Old 04-24-2015, 01:23 AM
mr.meroli
7th Gear
mr.meroli's Avatar
yes. The bumper is not attached though. I just hung it on for the photos. koni shocks were replaced as well.
Old 05-05-2015, 10:15 PM
CyCloNe!
CyCloNe!'s Avatar
still available?
CyCloNe! is offline
Old 05-07-2015, 05:02 PM
mr.meroli
7th Gear
mr.meroli's Avatar
yes still available. Ill be in the states on Monday if you are interested.
Old 05-19-2015, 11:22 AM
mr.meroli
7th Gear
mr.meroli's Avatar
PRICE DROP! first reasonable offer takes the vehicle.
Old 05-20-2015, 05:23 AM
Aj944sl
8th Gear
Aj944sl's Avatar
I'm interested.
Aj944sl is offline
Old 05-26-2015, 12:53 AM
mr.meroli
7th Gear
mr.meroli's Avatar
Just dropped the price again. I am doing this because I am headed to Germany next month around the 15th. The car will be taken off the market at that time.
Quick Reply: Porsche 944 turbo
