Mark this thread as Unsold
1996 Porsche 993 Race Car
Year: 1996
Make: Porsche
Model: 911
Mileage (numbers only please): 79844
Color: Red / black
VIN: WP0AA2991TS322881
Price (no $ sign please): $42500
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
NASA GTS3 / PCA GT5
Weight: 2700 lb
Mileage: 79,844
Body:
Getty Design front fiberglass bumper with splitter
Getty Design 3.8 RSR deck lid with EVO wing
Fiberglass hood
Fiberglass doors
All glass replaced with Lexan
Sunroof deleted
Engine/transmission:
Stock 993 Vario-Ram 3.6L engine
Steve Weimer chip in 1997 ECU - Rennsport Systems
--Dynojet chassis dyno: 250 hp / 228 lb-ft torque at rear wheels
K&N air filter
Fabspeed Supercup exhaust with Catbypass X-Pipe
Dual oil coolers
Transmission re-geared with Guard gears, steel synchros
-OEM 5th gear moved to 6th, new 3rd/4th/5th gears with equally spaced ratios between 2nd and 6th
Guard LSD
Sport clutch and flywheel
Race engine and transmission mounts
Reinforced engine hanger
Shift light
Hour meter
Engine hours (racing/DE): 69
Suspension:
993 RS/EVO front uprights
ERP Bump steer kit
TRG front strut camber plates
ERP control arm monoballs
ERP rear shock mount monoballs
ERP Kinematic toe links
ERP camber links
ERP toe links
25mm front TRG sway bar kit
22mm rear TRG sway bar kit
993 RS rear drop links
Redline solid rear subframe kit
Moton Club Sport shocks with reservoirs, 700 lb front / 900 lb rear springs
Front strut brace
Brakes
Stock 993 front calipers/rotors with cooling ducts
Stock 993 rear calipers/rotors
Steel braided brake hoses
Pagid RS14 front & rear
Tires & wheels:
2 sets of Forgeline 3-piece ZX3R wheels: 8x18 front, 10x18 rear
1 set of Porsche OEM 993 wheels (for rains): 7X17 front, 9X17 rear
1 set of Hoosier R6’s: 245/35x18 front, 295/30x18 rear
1 set of Continental Extreme Contact DR slicks: 245/40x18 front, 275/35x18 rear
1 set of Hoosier H2O’s: 245/40x17 front, 275/40x17 rear
Safety:
1.75” Custom built cage with Nascar bars
Schroth center net
Schroth window net
Recaro Pro Racer Hans XL seat with Brey-Krause back support (mount welded to cage)
6-point Schroth Hans belts
Momo suade steering wheel with Sparco quick release hub
Radio: Vertex VX-354, wired for helmet system. Shark fin antenna.
Data acquisition system: TraqMate TraqDash GPS system with GoPro camera
FireBottle 5 lb suppression system with inside and outside handles
Kill switch with inside and outside handles
Odyssey lightweight battery
F.A.S.T. cool suit box with helmet blower system
Included: OEM hood, doors, rear deck, front bumper.
Spare axle shaft
Included is weight for ballast to meet weight requirements in other classes / sanctioning bodies.
-not needed for NASA GTS3
-would need for PCA GT5
