Mark this thread as Unsold
FS: 1986 944 Turbo (951) black/black, 137k, M030, nice driver, recs, details, 79 pics
*SOLD AS OF 12/24* 1986 944 Turbo (951) black/black, 137k, M030, nice driver, 79 pics
Year: 1986
Make: Porsche
Model: 944
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 137000
Options (Please check ALL which apply): Air Conditioning, Alarm System, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Steering, Power Windows, Sunroof
Color: Black
VIN: WP0AA095XGN156480
Price (no $ sign please): $10500
Private or Dealer Listing: Private Listing
Location (Region): Texas
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Turbo
Stereo System: AM-FM CD
Flickr photoset gallery here (79 images)
Pictures do appear harsh in the direct Texas sun as it amplifies all details for better or worse in my lens, but looks better in person. Let me know if there’s anything you’d like to see more clearly without the glare that is in some of the photos. I may reshoot these on a partly cloudy day for serious inquiries (am already late getting this listed from a few folks waiting).
Maintenance in the past 14 months:
Professional paint correction and detailing by Details, Ltd. of Addison (also regularly hand-washed at home, 2 bucket system, Zaino)
Clutch master and slave cylinders with associated hoses
Hatch alignment and new pin seats (hatch does not chronically rattle or squeak)
Porsche idle stabilizer screw and o-ring (idles perfectly around 840rpm)
Porsche cassette holder/tray with hinge and Lart’s black leather armrest cover
Porsche hood struts
BOSCH cruise control module
BOSCH hatch lock motor
BOSCH MicroEdge wipers (all 3)
Texas inspection sticker good until 9/2013 if sold in-state (passed in 9/12, no emissions req., still has cat installed)
New front brake hoses, system bleed/flush/fill with Super Blue fluid
Lart’s braided fuel lines with OE Porsche damper line (engine bay lines, replaced originals)
BOSCH 3-bar FPR (fuel pressure regulator)
BOSCH FPD (fuel pressure damper)
BOSCH diverter valve (full boost at 1.8 bar)
Porsche coolant tank reservoir (clear, not yellow) and hoses (Coolant temperature regularly reads at and between the two white marks on the gauge)
BOSCH heater control valve and associated hoses (heater operational)
Coolant hose from engine to radiator
Upper and lower radiator hoses
BOSCH auxiliary coolant pump and thermostat (for turbo)
Facet speed and reference sensor wires
Porsche rear half-shaft axle assemblies and CVs
K&N air filter
BOSCH distributor cap, rotor, seal, cover
BOSCH copper spark plugs
BOSCH wireset
DuraLast red-top 3-yr. battery and Porsche cover cap
Rear tail lamp, brake, and side marker bulbs
Oil and filter change @ 133k, always changed every 3-5k (May; Mobil1 15W-50, needs again in 1k or right after driving home a long way)
A/C recharged (R134a, converted in 1995; cold enough for Texas)
Engine re-seal (front)
Balance belt
Cam belt tensioner
Timing belt and water pump (2011 @ 130k miles, 7k on new belt; change every 45-60k miles)
Clutch was measured at 21mm in 2011, 6k miles ago, no abusive launches, strong hookup
Tie-rod ends, control arms, bushings looked good in 2011, no pot holes or hard knocks
Had PPI and Clarks-Garage buying guide reviewed a year ago by an ex-Brumos mechanic in Nashville; all of these were ‘OK’ or addressed, have notes
Factory Options:
All codes: C02, 158, 418, 425, 431, 454, 533, 650, 946
Modifications:
Autothority/APE ‘Stage 2’ 270hp chip; dyno sheet included in records indicates 290hp, 170mph max; makes more power than a Turbo S (done in 1995)
Cross-drilled brake rotors; previous owner, still straight and true with lots of bite
Becker/Porsche CDR-220 AM/FM/CD stereo with AUX-in adaptor (swstereo.com) and MB Quart DKD 146 speakers (four 4x6); really great stereo (2012)
Custom milled aluminum black smartphone tray in ashtray location, holds an iPhone 5 and coins, misc. underneath (2012)
Comes with: what it still has plus a spares box
Porsche ignition, door keys, 1 set (original)
Porsche 944 Turbo owner’s manuals and folder (original)
Porsche 944 Turbo Workshop Manual binder (original)
Becker radio code in owner’s manual folder
Porsche air compressor, working (original)
Porsche spare tire, jack, tools (original)
Porsche black leather sunroof sleeve (original)
Porsche black screw-in front tow hook (new)
Porsche black touch-up paint
Porsche RL bumper pad (spare, RR replaced 2012)
Porsche DME relay spare (new)
Lloyds black floormats
CoverKing fitted windshield shade (save that nice dash!)
Black wooden dowel hatch prop
Porsche Club of America ‘Panorama’ and Maverick region ‘Slipstream’ magazines from the past year
Rennlist silver die-cut decal (new)
The replaced original ashtray, stereo under pocket, armrest (junk), speaker grilles (MB Quarts don’t clear these) and washer fluid pump (broken)
Bags of various spare Porsche 944 Turbo relays, fuses, switches, screws, brackets, bolts, nuts, clips, etc. for your partsbin
Bottles of coolant (Peak, 1/2), oil (Mobil1 15W-50, new), power steering fluid (AutoZone Dextron ATF, ¼), and some paper towels
Needs and FYIs: Don’t let the long paragraph scare you! I’m just OCD with cars
As with most 951s, the oil pan gasket leaks. Even my mechanic says this is OK and to just regularly check the oil (every fillup, Mobil1 15W-50, keep at top dipstick line). Garage drip tray recommended. Very minor power steering leak, check level every 1k miles. Electric hatch motor works but the switch is intermittent. Windshield washer system from the reservoir to the nozzles needs to be replaced- I just squeegee. The sunroof works great but the microswitch tab in the panel is handicapped, so you need to use something like a toothpick to engage it only for the UP operation- DOWN is normal. The hatch struts are worn, but 944 owners know if you put new strong struts on, they may make the hatch glass delaminate from the frame faster- I’ve just used a black wooden dowel (sometimes they stay up if it’s warm). The gas gauge when full reads 3.5/4. The oil gauge when fully topped up reads 4.5/5 (2/5 when idling). The car has a clean CARFAX, though you’ll note a mileage discrepancy- the previous-owner swapped in another gauge cluster rather than repair the faulty speedometer plastic gear (2010). The car shows to have 96,XXX miles but really has 136,XXX miles (am selling at 137k, still driving it some). CARFAX more obviously shows the actual mileage (rule of thumb- add 40k miles to whatever is on this working ODO… again, this is a very nice driver, but will not pass a PCA concours show car test). If you decide to address these items and really want to make it perfect, the nose and front bumper along with the side rub strips trim could use a respray as they’re faded from 26 years of road rash and touch-up paint spots. Otherwise and elsewhere, the original paint is really a very nice 8/10! A couple small dings on the hood. No critical showstoppers- just gas and go!
How to get it:
Experienced drivers and serious enthusiasts only who have funds ready. The car is available with a clean Texas title in my name in-hand for $10,500. This already takes into account a few of the needs. The car is an increasingly rare solid driver out of the box, with much documented recent maintenance, few needs, and a couple modest upgrades. It cleans up really well, drives smoothly and solidly, and isn’t a neglected project basketcase nor a concours trailer queen. This is one of the nicest, most sorted, turn-key, desirable and interesting black-on-black 951s on the market that is ready for you to drive home today. It’s been reliable and will start and go whenever you want. Available for a fresh PPI on your dime. If you’re a hobby mechanic like me, you can maintain this car using the wealth of open technical knowledge on clarks-garage.com and the Rennlist.com forums. And join PCA! As I have done with all other cars I’ve bought and sold online, funds are to be either wired to my bank or delivered in-person with a bank draft check. I trade you a title, bill-of-sale, and keys. A refundable $150 PayPal deposit is required up front to hold your place. Whether you’re local or flying-in, plan on a short overview of the car in my garage before you set off with it so you’re as familiar with it as possible. I can pick you up from DFW or Love Field with a full tank of gas and throw in a local case of beer if you want. Fly-in, drive home in your new Porsche, and see America along the way. Such trips to pick up a ‘new car’ are among my favorite life experiences. Plan a route and make a brief vacation out of it! You’ll be glad you did. If you don’t plan to travel, I have a great transport broker I’ve used a few times that can ship the car to your driveway on a transporter. Hope to hear from you soon!
Please post casual questions here in the thread and send serious discussions about a possible sale to my PM inbox to move forward. Thanks!
Beautiful, makes me miss my old 951.
Thanks to all- I am looking forward to finding a great home for this car. I should note the needs were updated as the clutch pedal item was further diagnosed and is being taken care of- I am having a new BOSCH clutch master and slave cylinder installed early next week.
Also, I'm thankful that the car is featured today! Welcome germancarsforsaleblog.com readers! Anyone can also contact me via E-mail at sentinelist at synthesistechnologies dot com.
Nice pics. I can even see the construction on 635.
GLWS.
GLWS.
Thanks- this was the only decent location I could find amidst the contruction when I went out for lunch!
The car has fresh master and slave clutch cylinders and associated hoses as of today and the feel is great! It will be listed on eBay in the next several days if no hard interest is spurned here.
