Mark this thread as Unsold
1987 911 Carrera "Upgrade-Itis" ftd. in Excellence Magazine
Year: 1987
Make: Porsche
Model: 911
Cont. Porsche Models: 911
Mileage (numbers only please): 29000
Color: Summer Yellow
Price (no $ sign please): $55000
Private or Dealer Listing: Private Listing
Location (Region): NorthWest
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
-One of only 5 Carrera coupes imported into the US in 1987 in this unique, optional color. (Available only in 1987 & 1988)
-Euro delivery with sport package and Certificate of Authenticity.
Build Highlights
· MOTEC 3.6L, Twin Plug w/G-50 Transmission
· Close ratio, custom gearing w/80/50 Guard LSD
· 993 Twin Turbo brakes w/front Slotted AP rotors
· JRZ Dampers: Custom; valving, spindle height/angle, coiled rears (rear torsion bar delete)
· Full, welded cage (with sun visors J)
· Recaro seating w/Alcantara inserts
SPECIFICS
· Engine/Clutch/Transmission
o MOTEC 3.6L Engine - 29000 miles on engine, approx 145600 on the chassis
§ WEVO motor mounts
§ 11.3:1 p/c, Twin Plug
§ 332 FWHP=289 WHP !
§ Elgin C-2 Super cam
§ Andial progressive racing valve springs with titanium retainers
§ Adjustable, rising-rate fuel pressure regulator
§ GT3 Injectors
§ Baffled, enlarged oil tank w/Aeroquip lines
§ European 964 RS Heater/Blower Bypass pipe
§ MOCAL 72 row, Front mounted, Auxiliary oil cooler: Custom mounted into stock front valance/front boot with angled, fully boxed plenum – Still allows for stock, collapsible spare tire and an RS America windshield-washer reservoir !
§ Clewitt serpentine fan belt kit (w/custom belt remover tool !)
o Clutch
§ Kennedy lightweight pressure plate
§ Sachs ’73 Turbo disc
§ Patrick Motorsports lightweight flywheel
o Transmission
§ G-50 with custom calculated gears, (2nd-5th)
§ Steel syncros,
§ Guard GT 50/80 LSD,
§ Original mfg. prototype WEVO shifter (31% throw reduction – a work of art in itself !)
· Exhaust
o Stainless Steel “S-Car-Go” custom headers with custom fabricated SS heater boxes
o “Burns” SS 2.5” piping with V-Band clamps
o Dual-in/dual-out SS Custom “Flowmaster” muffler
· Suspension
o Tarett fully adjustable front and rear sway (anti-roll) bars. Front torsion bar – 28mm
o Elephant Racing PolyBronze Suspension Bearings throughout front and rear
o Elephant Racing ASP Adjustable Spring Plates
o Elephant Racing De-Cambered A-Arm Ball Joints
o Elephant Racing Turbo Tie Rods
o Elephant Racing Bolt-On, Rod-End, Adjustable Bump Steer Kit
o WEVO carbon fiber strut brace w/integrated monoball bushings
o Dyno Tuned, JRZ double adjustable dampers. (w/remote reservoirs)
§ Through the firewall, ‘Drybrake’ quick disconnect for rears to allow for easy maintenance removal.
§ Custom front struts with raised spindles to accommodate additional camber adjustment.
§ Rear shock towers gusseted to ’74 RSR specs to accommodate the coilover springs. Rear torsion bars deleted; replaced with 550# mainsprings + 150# tender springs for street compliance
§ All four remote canisters mounted inside on custom hangers: ‘Out of the Elements’
· Brakes
o Front – 993 Twin Turbo calipers (Black) w/332mm AP cryo slotted rotors
o Rear – 993 factory caliper (Black) w/’cast’ holed rotors
o Pads – Street-Textar/ front & rear, Track- Pagid/Yellow front, Black rear
· Wheels
o 3 Sets of Fikse wheels: Profil Split 5, FM5, Mach 10 (Front – 9 × 17, Rear – 10 × 17)
o Current tires: Street – NEW Pilot Sport 2; 235/265, Track – Hoosier; 245/275 (4 track days, lots of fun time remaining !)
· Interior
o Tachometer and Speedometer recalibrated and refinished by North Hollywood Speedometer with Orange $$ at 8Krpm mark (cost reminder of a zing J)
o Recaro SRD (now called Speed) sport seats x 2, SPG carbon fiber driver’s racing bucket; all on sliders and with Alcantara inserts
§ Schroth 6 point racing harness: Drivers-2”into 3” for HANS device. Passenger-3” 6 point
o Alcantara trimmed out interior
o Rear seat delete replaced by RS America storage compartment shelf (Redone with custom fabricated honeycomb carbon fiber)
o Fully gusseted and welded 1.75” steel cage with appropriate cross bracing and low sidebars. (easy entry and exit) Mounting gussets for sun visors and stock seatbelts
· Exterior
o Front lip spoiler accessed cooling ducts for front brakes, including A-arm clamshells.
o 964 aerodynamic carbon fiber (electric) side mirrors
o European rubber trim inserts replace US sidemarkers
o H-4 headlamps with European 12 volt city running lights
o European taillight assemblies – sidelight delete with white enamel inner backing instead of the US chrome
o European Rear Porsche Reflector with integral fog/brake lights
o Heavy, rear ‘rubber’ bumperettes deleted, cast aluminum bumper retained and reverse mounted to keep the impact bumper shocks
o Front/rear fenders rolled. Rear fenders additionally stretched with rear fender valance extension to accommodate larger wheel/tire sizing
Interior Pics and More
Yes indeed! Here's a link to my photobucket album of the car. I have chassis and underside shots too.
http://s196.photobucket.com/user/rya...?sort=6&page=1
I'd like to bump this up the list to gauge interest again. Please also keep in mind that all competitive and reasonable offers will be entertained.
Please let me know if there are any questions!
My apologies, I'm not entirely sure! Since I'm a WA resident and the car is registered in WA, I'm unfamiliar with the CA smog requirements. Are there any specific numbers they're looking for to pass? Perhaps that's something I could find for you on old emissions testing results. Here in WA, the car is considered a Collector Vehicle (25+ yrs old) and is no longer required to take emissions tests.
California is 1975 and older. If the seller can produce a current smog test result you can compare the values to what is required to pass on the California test but...that is still not a guarantee.
Thanks for the responses everyone!
Docron, if you can let me know exactly what CA is looking for, I might be able to come up with something. The car hasn't taken any emissions test in a few years, but I have access to a tailpipe gas analyzer so I may be able to find out what you need to know.
Really nice car!
just an FYI, in CA given the age of the car (not old enough to be exempt) "officially" you'll need to not only pass the sniff test but also pass the visual which will compare all the OEM smog equipment list to what is on the car. If that's missing you'll fail visual, no matter if it passes the dyno test.
Unfortunately CA is a PITA with this whole process.
here's the guide to the process:
http://www.bar.ca.gov/80_BARResource...08-09%20V3.pdf
Ok, I sold my SC randomly today on christmas to a friend. I've been eyein' this car since september.
Can I get some pics of the car with the other wheels? Maybe some track pics? You can tell alot of about a cars setup with simple track pics.
There are few things I don't like about the car at all, that would stop me from paying what you need for it but aren't deal breakers.
Can I get a number PM'd to me. I'd like to speak about the vehicle and see if we can come to a deal.
Cheers,
Bisan
Cheers,
Bisan
'87 911's didn't come from the factory with a 3.6L, so unless you have all the emissions equipment from the year of the engine (installed by Porsche or CARB exemption), the car would fail the visual test in CA.
If your 3.2 was just punched out to 3.6, then you would be OK as long as the factory emissions equipment is installed and working properly.
