Wheel and Tire Forum
OZ and TireRack introduce the Leggera HLT
Old 01-08-2018, 10:09 AM
  #31
Croc999
Croc999's Avatar
yes.
they're a little bit loose - so some teflon tape can be used to make sure OEM cap seats tight.
one of my OEM caps eventually popped out and got lost even though i used above method.
the issue is that those wheels are dark silver - OEM caps don't match wheel's color - neither bright silver one nor grey one.
I eventually plastidipped outer ring of the OZ cap in red and used it like this.
Old 01-08-2018, 06:00 PM
  #32
brad@tirerack.com
Former Vendor
brad@tirerack.com's Avatar
We don't list an OEM cap option for the Leggera, so if you tried to use an OEM cap you may have to glue them in. It has a 71.5mm bore diameter for the wheel, and uses a 76mm diameter cap with a 62.5mm logo diameter.
Old 01-11-2018, 11:43 AM
  #33
Need4S
Need4S's Avatar
Thanks for the info. Silver and grey don’t match anyway, but maybe these would work?
https://www.suncoastparts.com/produc...1BLKMATTE.html
Old 01-11-2018, 06:55 PM
  #34
brad@tirerack.com
Former Vendor
The sheen is matte on those caps and the OZ's are gloss. It's not a perfect match, but is better than silver.
Old 03-18-2018, 11:37 AM
  #35
Notwaiting
Notwaiting's Avatar
So using the Porsche center cap would realistically not work without a concern for the cap falling out at some point?
Old 03-18-2018, 11:47 AM
  #36
Croc999
Croc999's Avatar
i lost one.
Old 03-18-2018, 12:49 PM
  #37
Notwaiting
Notwaiting's Avatar
I wonder if some silicone glue would work
Old 03-19-2018, 05:09 AM
  #38
Croc999
Croc999's Avatar
as i wrote earlier - teflon tape around it worked good enough.
Old 03-19-2018, 05:58 PM
  #39
pmgoodwin
pmgoodwin's Avatar
I just saw the original post today and coincidentally this morning I decided to change the wheels I have on my '87 Targa. This was my track car and I'm converting it back to a street car.
I went to the Tire rack page and it just says these wheels don't fit my car. The Tire rack site will only show me 16" and 17" wheels for my car. I want an 18" wheel that is wider than stock
Is there a way to look at the wheel options that will fit my car that has flares to take wider wheels?
Paul
Old 03-19-2018, 06:24 PM
  #40
brad@tirerack.com
Former Vendor
Available Porsche fitments are:
19X8.5 5-130 ET53
19X10 5-130 ET40
19X11 5-130 ET50
19X11 5-130 ET65
19X11 5-130 ET40
19X12 5-130 ET51
20X8.5 5-130 ET55
20X8.5 5-130 ET50
20X9 5-130 ET50
20X10 5-130 ET45
20X11 5-130 ET50
20X11 5-130 ET65
20X12 5-130 ET51
You'll need to go with the Allegerita if going for 18" Call me if I can help with sizing.
Old 03-23-2018, 03:13 PM
  #41
ReidN
ReidN's Avatar
19X8.5 5-130 ET53
19X10 5-130 ET40
19X11 5-130 ET50
19X11 5-130 ET65
19X11 5-130 ET40
19X12 5-130 ET51
20X8.5 5-130 ET55
20X8.5 5-130 ET50
20X9 5-130 ET50
20X10 5-130 ET45
20X11 5-130 ET50
20X11 5-130 ET65
20X12 5-130 ET51
Hey so I bought the 12" challenge wheels for my 996 TT. What fronts are close to a match as you discontinued the fronts. Wheels are for track so??
Old 05-27-2018, 09:09 AM
  #42
Mdnyte
Mdnyte's Avatar
if anyone is interested. I have a mint condition set for sale in the classifieds.
Old 06-14-2018, 12:56 AM
  #43
Andrew Chung
3rd Gear
Andrew Chung's Avatar
still available if so pm specs looking for a set 19 or 20s
Old 02-06-2019, 05:41 PM
  #44
BobbyLKPG
BobbyLKPG's Avatar
Does the 20X12 5-130 ET51 and 20X9 5-130 ET50 fit the 997 Turbo ?
Old 02-06-2019, 08:03 PM
  #45
brad@tirerack.com
Former Vendor
20 x 9 ET 50 fits OK. The 20 x 12 would be 13mm less clearance both inside, and out from the OEM wheel. It would be aggressive outside as long as the tire stays at 305.
Quick Reply: OZ and TireRack introduce the Leggera HLT
